cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
vandermerwe
Jun 16, 2013Master
No, just add the new disk to the free slot when you get it, having of course tested it first when you get it.
I would not start moving the disk in and out unnecessarily, and it makes absolutely no difference which slot it is in.
