cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
vandermerwe
Jun 16, 2013Master
The early readynas devices ( and the newer ones to a degree) are notorious for this sort of behaviour when a disk fails. There are all sorts of presentations of failed disks, apart it seems from the unit simply telling you that a disk has failed. The forum is full of troubleshooting which ends up revealing a hard disk failure when the initial problem was unclear.
