cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
vandermerwe
Jun 18, 2013Master
Any 1 tb drive on the hardware compatibility list should be fine. The western digital red series is popular now and has good reviews.
If your data is accessible from the Nas with disk 2 in then you can just add the new disk to slot 1. The volume will then resync which will take several hours. You do not need to move disk 2 to slot 1.
You should always have a backup, particularly during volume changes, resyncs and expansion.
