gragus
Mar 05, 2012Aspirant
Can't connect to SSH/Frontview on NV+ after upgrade FW 4.1.8
Hi, I upgraded my Ready NAS NV+ to firmware version 4.1.8 using this from the SSH command line: # cd /tmp # wget http://www.readynas.com/download/RAIDiator/RAIDiator-4.1.8 # echo /tmp/RAIDiat...
mdgm-ntgr
Mar 05, 2012NETGEAR Employee Retired
What version of RAIDiator were you running before?
A firmware update should not result in the loss of the ability to connect via SSH. So it refuses the connection? Did you remember to attempt connecting as 'root'?
Do you have any add-ons installed or stuff you've installed via SSH? If so, what?
Why did you update via SSH? Was Frontview not working before doing the update?
