gragus
Mar 05, 2012Aspirant
Can't connect to SSH/Frontview on NV+ after upgrade FW 4.1.8
Hi, I upgraded my Ready NAS NV+ to firmware version 4.1.8 using this from the SSH command line: # cd /tmp # wget http://www.readynas.com/download/RAIDiator/RAIDiator-4.1.8 # echo /tmp/RAIDiat...
mdgm-ntgr
Mar 05, 2012NETGEAR Employee Retired
Data will be left intact when you do an OS re-install. It may fix the problem with not being able to get SSH access.
Would recommend you have a backup of important data just in case before doing this.
