Bubba-Ho-Tep
Oct 17, 2020Aspirant
Can't Disable "Active Snapshot" When Trying to Expand Volume on ReadyNas Ultra 2
I currently have two 2-TB drives installed in my ReadyNas Ultra 2 Plus. Volumes are set to RAID Level X-RAID2. I am almost out of space so I decided to upgrade using 2 6-TB Seagate Ironwolf driv...
Oct 17, 2020Guru - Experienced User
Did you try rebooting the NAS?
- Bubba-Ho-TepOct 17, 2020Aspirant
StephenB wrote:Did you try rebooting the NAS?
Thanks for the quick response.
Yes, I tried rebooting several times with the same result.
- StephenBOct 17, 2020Guru - Experienced User
There's a post here that should help: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Expansion-Problem/td-p/838303
If you want to try this, you will need to install "enable root ssh access" from here: https://kb.netgear.com/24551/ReadyNAS-Add-ons-for-RAIDiator-4-2-x86
Then log in with ssh as root, using the NAS admin password.
Thanks. I'll give that a shot.
