uffgnu14
Jun 13, 2017Luminary
Can't get remote Wake On Lan working on ReadyNAS Ultra2Plus with OS6
Hi, I have problem with setting up remote WOL to my RN Ultra2Plus running OS 6.7.4 connected to a Netgear R6400 router. It's the first time I'm trying WOL with my RN and so did not tried with th...
Jun 13, 2017Guru - Experienced User
I don't see how this can be the NAS, since it has no idea if the WoL packet is coming from the internet or coming from the local LAN.
But it's also clear that the packet is arriving at the router. It's possible that the router has lost track of which ethernet port the NAS is connected to, so it doesn't know how to deliver the packet. Is the router on a power schedule?
You could try reserving the IP address in the router, instead of configuring a static address in the NAS. Not sure if that will help or not, but it does no harm (and in my opinion address reservation is a better way to manage IP addresses).
But you might need to go with a power schedule on the NAS (either instead of or in addition to the WoL). If the router turns on for an hour perhaps 2x a day, then the router might not lose track of it.
- mdgm-ntgrJun 13, 2017NETGEAR Employee Retired
Are you able to send me your logs (see the Sending Logs link in my sig)?
- uffgnu14Jun 13, 2017Luminary
Hi mdgm,
Logs sent.
Best regards,
Ulf
Hi StephenB,
Thank's for your suggestions.
I changed to RN-DHCP and executed a WOL after about 6 hours RN downtime. Not working.Best regards,
Ulf
