uffgnu14
Jun 13, 2017Luminary
Can't get remote Wake On Lan working on ReadyNAS Ultra2Plus with OS6
Hi, I have problem with setting up remote WOL to my RN Ultra2Plus running OS 6.7.4 connected to a Netgear R6400 router. It's the first time I'm trying WOL with my RN and so did not tried with th...
sotrack
1. Try to get local Wake On Lan first inside local net. If your local WOL doesn't work then remote WOL will not work also.
2. Turned off NAS haven't got local IP address even if NAS IP is fixed in your router. And forwarding port 9 to fixed RN-IP does not make a sense. You need forward port 9 to specific broadband address 192.168.1.255 or 192.168.1.254 or 192.168.1.* This mean WOL package will be sent to all devices in local net including devices without IP. This address is dependent of router. My router Mikrotik use 192.168.1.254, for example. A lot of routers doesn't allow use broadband address and can not be used for remote WOL.
3.Port 9 forwarding use UDP protocol. TCP is not required.
4 For remote WOL you need use router external IP address not local RN IP
Jun 13, 2017Guru - Experienced User
sotrack wrote:
And forwarding port 9 to fixed RN-IP does not make a sense. You need forward port 9 to specific broadband address 192.168.1.255...
I think that depends. If the packet reaches the NAS in the first place, the NAS should wake up no matter what IP address in the the IP destination field of the packet.
The problem is whether the router can figure out how to deliver the packet in the first place. The fact that it sometimes works suggests that the router will deliver the packet in at least some situations. The NAS can't respond to ARP when it is powered off, but if the IP address / mac address association is in the ARP cache the router should still be able to deliver the packet to the correct ethernet port.
That said, I've never gotten this to work with my ISP and routers. There's a handy add-on for OS 4.2 NAS that will send WoL packets when you give it an HTTP request that includes the mac address. My pro-6 is on 24-7, and I have used it to wake up other devices on my network when I'm away. Unfortunately there is no OS 6 equivalent.
- SandsharkJun 13, 2017Sensei
When it won't wake up, are the switch and NAS network LED's showing a connection? It'll be a 10M one, but they should show something. If they are not, you are probably experiencing a problem caused by a "green" switch turning down the power too much. A better cable might fix it, but probably not.
- mdgm-ntgrJun 13, 2017NETGEAR Employee Retired
The logs show that WOL is enabled.
- StephenBJun 14, 2017Guru - Experienced User
The OP's first post says that WoL is working reliably on the local LAN. His problem is getting it to work remotely (over the internet).
- uffgnu14Jun 14, 2017Luminary
Hi,
Short summary.
LAN WOL:
Working fine for RN and PC.Remote WOL (Port forwarding port 9):
Working fine for PC.
Working for RN for a while but NOT after a RN downtime (time not tested, for now 6 hours noticed).
Also strange that despite events in the router log RN is not responding.Best regards,
Ulf
- sotrackJun 14, 2017Luminary
The IP address in the the IP destination field of the WOL packet is not used. You are correct here. But IP address from port forwarding table is independent of IP inside WOL packet. If NAS IP address is not registered by DHCP server or doesn't exist in temporary ARP table then port 9 will not be forwarded by router to NAS and WOL packet doesn't reach NAS. This is why broadband request should be used in port forwarding for WOL packet.
LAN WOL use broadband request and it is working.
sotrack wrote:
...or doesn't exist in temporary ARP table then port 9 will not be forwarded by router to NAS and WOL packet doesn't reach NAS.
We completely agree, and that's what I tried to say in my earlier post. It can work if the binding is in the ARP cache, otherwise it won't.
Last time I checked, Netgear routers didn't allow forwarding a packet to a broadcast IP address.
