thecause
Oct 04, 2008Follower
Can't print using ReadyNAS duo
I just purchased a ReadyNAS Duo and I'm having trouble using the print server. I am using windows XP SP2 on both my desktop and laptop and have an HP Officejet G55. Connecting and discovering the prin...
latitudehopper
May 18, 2009Aspirant
I am having this problem also. Tried logging in with no luck. Printer (Canon ip4200) found via Bonjour on OSX, installed with Open Gutenprint drivers. When i click print it sends then returns this error
Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
Any ideas?
Cheers!
EDIT: should point out, it is on, plugged in etc etc.
Any ideas?
Cheers!
