thecause
Oct 04, 2008Follower
Can't print using ReadyNAS duo
I just purchased a ReadyNAS Duo and I'm having trouble using the print server. I am using windows XP SP2 on both my desktop and laptop and have an HP Officejet G55. Connecting and discovering the prin...
Macca1602
Nov 07, 2009Aspirant
Thanks for the previous post. It has helped me print from my Vista computer that is wired to my Linksys WRT54GXv2 router. The issue I have now is that when I attempt to use the same instruction for my netbook (XP) which is connecting wirelessly, I just keep receiving the message that is it unable to connect whether I use the local hostname or the IP of the local host. I've managed to ping the NAS itself using the IP address but not the local hostname. From within the router I'm configured it so the UPNP is enabled and I can see the NAS link for Frontview but that is as far it goes. I do think think this is some configuration problem with the router in terms of the wireless setting but I've looked through this setting and nothing is jumping out at me. Can anyone help?
Thanks
Macca
Thanks
Macca
