thecause
Oct 04, 2008Follower
Can't print using ReadyNAS duo
I just purchased a ReadyNAS Duo and I'm having trouble using the print server. I am using windows XP SP2 on both my desktop and laptop and have an HP Officejet G55. Connecting and discovering the prin...
familien
Oct 19, 2010Aspirant
mapofe wrote: Hope it helps and that you can read german.
This guy seems to have found a solution.
http://www.wawerko.de/readynas-duo-als-printserver-einsetzen-und-mit-windows-xp-drucken+2385.html?sstep=1
Thanks for this.. I was just searching here and there as I had some problems with the printing. Thanks
http://www.familienladen24.de//krokodil-kostuem-karneval-fasching-karnevalskostuem-f13-m-6-10194
