doug_jensen
Oct 20, 2015Aspirant
Can't re-insert drive in NV+
The title says it all. Somehow when re-inserting a drive, the gray pull-bar with the black unlatch button closed and locked before the drive was fully inserted. I cannot finish insertion because the...
- Oct 20, 2015
Thank you, that solved the problem!
Oct 20, 2015Guru - Experienced User
This is the disk tray with the round release button?
