KWheelerAZ
Sep 14, 2015Aspirant
Can't rename files/folders RN312
I have a client with a ReadyNAS 312 with 2 x 2TB HDD's running OS 6.2.4. They are accessing the RN via Windows Explorer from systems all running Windows 7 Pro x64 with all current patches & service p...
Sep 14, 2015Guru - Experienced User
I sometimes see folder renames (or deletes) fail on my various NAS - usually with an error that a file is open in another process. My workaround is to browse to https://nasip/shares and delete (or rename) the folder via http. Alternatively, wait a while and try again.
Not great workarounds, and it is annoying when it happens.
FWIW, I think thumbs.db is the culprit You can prevent thumbs.db from being read/writen though a windows policy setting (user configuration\administrative templates\windows components\windows explorer\turn off the caching of thumbnails in hidden .thumbs.db files
KWheelerAZ
Sep 17, 2015Aspirant
Thanks for the input. I'll give that a try. I hate to modify that policy as it affects everything everywhere. I'd feel better if I could isolate that to just the network drives.
I'll let you know what happens ...
- StephenBSep 17, 2015Guru - Experienced User
Which is why I just live with it.
