KWheelerAZ
Sep 14, 2015Aspirant
Can't rename files/folders RN312
I have a client with a ReadyNAS 312 with 2 x 2TB HDD's running OS 6.2.4. They are accessing the RN via Windows Explorer from systems all running Windows 7 Pro x64 with all current patches & service p...
KWheelerAZ
Sep 21, 2015Aspirant
Okay, so I turned on HTTP access to the Shares in question. And I can now open them up in a web browser. Two questions; First, what do I do about WebDAV? On or Off?; Second, I don't see a way to "rename" the folders in my browser (which is Chrome 45.0.2454.93 m).
Thoughts? Opinions?
TIA
StephenB wrote:I sometimes see folder renames (or deletes) fail on my various NAS - usually with an error that a file is open in another process. My workaround is to browse to https://nasip/shares and delete (or rename) the folder via http. Alternatively, wait a while and try again.
Not great workarounds, and it is annoying when it happens.
FWIW, I think thumbs.db is the culprit You can prevent thumbs.db from being read/writen though a windows policy setting (user configuration\administrative templates\windows components\windows explorer\turn off the caching of thumbnails in hidden .thumbs.db files
Sep 21, 2015Guru - Experienced User
With OS 4 you can rename/delete from via https://nasname/sharename.
With OS 6, I think you need to use admin UI to do that. Enabling WebDav in Chrome has no effect.
