nickface
Jan 04, 2017Tutor
Can't upgrade firmware over GUI or USB #27886772
Hi all; I've actually been trying to upgrade the firmware for about 2 years, and have just got round to setting it up again on a new network, now that I've moved house.
So, to clarify:
- Jan 04, 2017
Try ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
You can update direct from ReadyNAS OS 6.2.4 to ReadyNAS OS 6.6.1 which was just released yesterday. Unlike the update to 6.6.0 from 6.2.4 it doesn't require an intermediate update.Edit: Sounds like you've already followed the required upgrade path for 6.6.0 by updating first to 6.5.2 using the above workaround then updating to 6.6.0 normally.
As for USB Boot Recovery not working either you formatted the USB key incorrectly or it's an incompatible one or the process to boot off USB was not followed correctly. You can have to try a number of USB keys before finding one that works.
nickface
Jan 05, 2017Tutor
The instructions are pretty comprehensive, I agree, and easy enough to follow. But if only some USB drives work, there must be a reason, right? And that reason could be communicated to people, to give them more of a chance of finding one that works, no?
As I said, I have five USB drives at home, of varying size and manufacture date, and none of them worked. Mind you, given that it was a checksum error, they probably wouldn't have worked even if they were the right sort of drive...
mdgm-ntgr
Jan 05, 2017NETGEAR Employee Retired
That checksum error issue is completely irrelevant to USB Boot Recovery. That error on e.g. 6.2.5 was caused by something specific to some firmware releases.
USB manufacturers don't promote whether their keys are compatible. The only way to verify if they are is to test them.
