rodneyedgar
Oct 09, 2011Aspirant
CASE#16885582 ReadyNAS Ultra 6 Running But Not Respoding
I have a ReadyNAS Ultra 6 with 12TB of storage. The device has been running fine for a year, but I am currently having issues. 1. Blue light is on with display showing ReadyNAS with fan running. 2...
rodneyedgar
Thanks for the input. Right after I got the unit, the support team had me remove all disks from the system and do a reset using a paper clip. After it recovered I inserted the disks back in the correct order and restarted with no data loss. I'll have to try tech support tomorrow. Puzzling that the system just turn on, displays ReadyNAS and simply goes nowhere else.
Thanks again,
Rodney
Thanks again,
Rodney
