rodneyedgar
Oct 09, 2011Aspirant
CASE#16885582 ReadyNAS Ultra 6 Running But Not Respoding
I have a ReadyNAS Ultra 6 with 12TB of storage. The device has been running fine for a year, but I am currently having issues. 1. Blue light is on with display showing ReadyNAS with fan running. 2...
Terje_Hagen
Oct 22, 2011Aspirant
I have the exact same configuration, both the NAS and capacity bought on Oct. 14 2011, and also the same problem.
But, I found the solution (at least for me).
It turned out that there is a slight design flaw. The mother board is placed slightly too close to the back panel of the unit. This makes the reset button being pressed all the time.
I opened the case (side panel closest to the reset switch), folded a piece of paper, and placed it between the end of the mother board and the back panel.
This forced the mother board away from the back panel just enough so that the reset switch is not pressed.
Problem solved ==> case closed (at least mine).
