skeeboze
Oct 31, 2011Aspirant
Change Permission issue (SOLVED)
I have a ReadNAS 3100 RAIDiator 4.2.15 Joined to Windows 2003 Domain I've gone through the video and documentation to set NTFS permissions on the share. I've created a share called SALES with def...
skeeboze
Dec 12, 2011Aspirant
The last issue I had was that Office files would open in Read Only if it was modified by the Readynasadmin account and then someone in the Sales group opened it.
To fix that, under Advanced CIFS Permissions for the share Enable "Automatically set permissions on new files and folders AND Enable Do not allow ACL changes to be more restrictive than this. Both must be enabled!
Group Rights: Read/Write
Everyone Rights: Read/Write
Use these rights for both new file and new folder creation.
Oplock can be enabled and does seem to play nicely with Office.
When editing an Office file office will create a new file (temp). Once the edit is done and Office is closed it will delete the original file and rename the temp file to the original file name. This is what screws up Samba.
Enjoy!
Enjoy!
