Blues11
Oct 07, 2016Luminary
Check for updates not connecting
Usually when I click on the main page "Check for updates" it almost immeidately comes back saying "You are running the latest" or something like that. Today it takes 5 or 10 seconds and comes bac...
- Oct 08, 2016
Hello Blues11,
The update server included 6.6.0 yesterday, that could be the reason why you were having some issues when checking for updates. Nevertheless, I am glad it works now and thank you for confirming that everything's okay now.
To close this thread, please mark one of the posts that you think is appropriate as the solution. Please feel free to post any suggestions, comments or questions. We value your inputs and feedback.
doegox
Oct 07, 2016Aspirant
A friend got the same issue today after the firmware update.
Try to disable the IPv6 support on your network interfaces.
It solved the issue here.
- Jul 31, 2022Retired_Member
