Blues11
Oct 07, 2016Luminary
Check for updates not connecting
Usually when I click on the main page "Check for updates" it almost immeidately comes back saying "You are running the latest" or something like that. Today it takes 5 or 10 seconds and comes bac...
- Oct 08, 2016
Hello Blues11,
The update server included 6.6.0 yesterday, that could be the reason why you were having some issues when checking for updates. Nevertheless, I am glad it works now and thank you for confirming that everything's okay now.
To close this thread, please mark one of the posts that you think is appropriate as the solution. Please feel free to post any suggestions, comments or questions. We value your inputs and feedback.
JennC
Oct 07, 2016NETGEAR Employee Retired
Hello Blues11,
How about adding 8.8.8.8 as DNS address in the admin page's Network > Eth 0 or 1> Settings > IPv4? Then test again.
viperhansa
Oct 07, 2016Virtuoso
Hi JennC,
I tested that and it seems to work.
I also updated to 6.6.0 and went back to my old DNS, that worked also now.
Thanks for the support.
Regards
Hans
- JennCOct 07, 2016NETGEAR Employee Retired
Hello viperhansa,
Thanks for sharing what worked. Thanks to @doegox too for adding a solution.
Hopefully, these will help Blues11 too.
- Blues11Oct 07, 2016Luminary
Yes, thanks for all the tips. I'm up and running with 6.6.0.
The strange thing is that I didn't do anything. I checked on my Network and I have always had IPv6 disabled. I had also had 8.8.8.8 set up under DNS Servers. So I'm not sure that it's anything I did.
Regardless, the system's working fine. Thank you again.
- JennCOct 08, 2016NETGEAR Employee Retired
Hello Blues11,
- Jul 31, 2022Retired_Member
