tenney
Jan 11, 2012Aspirant
chmod not working (Pro 6, 4.2.19)
On my new Pro 6 (running 4.2.19) I created a new share and then backed up a share over from my NV+. I need to be able to "chmod" specific files here and there, now and then. and it does not work. ...
spiderman1
Jan 11, 2012Guide
Here, e.g., is a command line example smb to the readynas pro 6 as "admin" to "c", and then cd''ed to the directory:
Are you SSHing into the Pro 6? If so, have you tried to the sudo chmod XXX "FILENAME" command to see if that works.
