janpeter1
Mar 26, 2019Luminary
Choice of file system for external backup hard disk
Hi,
I have used my ReayNAS 314 for a few years and run the latest OS on it. Regularly I make backup on an external HD of the important part of what is stored on the NAS. I have two external bac...
Mar 26, 2019Guru - Experienced User
janpeter1 wrote:
I consider now to make the full backup from scratch on the EXT3 disk and I consider to swith to BTRFS here too. I am just curious what you would recommend. Is BTRFS "stable" enough to use for both my backup? Other reasons to actually continue with EXT3?
I think it's stable enough (and if it weren't then you shouldn't use it for either backup). The main thing is that you want to be able to access the files using something other than the NAS. If you have a linux PC, then you should install btrfs, and make sure you can read both back up drives. If you don't have a linux PC, then you should be using NTFS.
janpeter1 wrote:
Is it good too divde the backup in parts so that the NAS can "rest" for some time or it is just to run it all.
I think it's fine to just run it all. Also, if you are making incremental backups, then it's a good idea to occasionally make a full one (just to make sure there are no underlying disk errors).
- HopchenMar 26, 2019Prodigy
I use BTRFS on my USB devices. I like that because I can snapshot by data on the USBs. It is fantastic for backup versioning, for example.
- StephenBMar 26, 2019Guru - Experienced User
I assume you are doing that yourself (from ssh), since the built-in backup jobs don't have that facility. Is that correct?
- HopchenMar 26, 2019ProdigyYup that is correct. I wish that was a feature in the NAS admin panel. I have a cronjob that does this for me :)
