CaryTheLabelGuy
Dec 22, 2011Aspirant
CNID DB error using AFP in Lion
My rig: late 2011 iMac 27inch 3.1Ghz Quad Core i5 running OS X Lion ReadyNAS NV+ RAIDiator 4.1.8 4x1tb Hitachi drives I'm having an issue whenever I try to use AFP on the ReadyNAS NV+. The pro...
mdgm-ntgr
Jan 08, 2012NETGEAR Employee Retired
eightpointacres:
yoh-dah wrote: The AFP service in 4.1.8 updates the CNIB DB on first access, and during that access, writes are disabled on the share. If you have a ton of files in that share, it may take awhile to update the DB. Once the update process is complete, you should have full read/write access to the share.
