CaryTheLabelGuy
Dec 22, 2011Aspirant
CNID DB error using AFP in Lion
My rig: late 2011 iMac 27inch 3.1Ghz Quad Core i5 running OS X Lion ReadyNAS NV+ RAIDiator 4.1.8 4x1tb Hitachi drives I'm having an issue whenever I try to use AFP on the ReadyNAS NV+. The pro...
Fandu
Mar 12, 2012Aspirant
This is a log of the CNID error being generated:
Any idea why requests to dbd are timing out?
ReadyNAS:~# tail -f /var/log/netatalk.log
Mar 12 18:11:49.501555 afpd[12911] {uams_dhx2_pam.c:653} (I:UAMS): DHX2: PAM Auth OK!
Mar 12 18:11:49.501836 afpd[12911] {auth.c:266} (N:AFPDaemon): AFP3.3 Login by ReadyNAS
Mar 12 18:11:49.636085 afpd[12911] {volume.c:2045} (I:AFPDaemon): CNID server: localhost:4700
Mar 12 18:12:33.023880 afpd[12911] {cnid_dbd.c:439} (E:CNID): transmit: Request to dbd daemon (db_dir /c/.timemachine) timed out.
Mar 12 18:12:33.024161 afpd[12911] {file.c:264} (E:AFPDaemon): Reopen volume /c/.timemachine using in memory temporary CNID DB.
Mar 12 18:13:15.387267 afpd[12911] {auth.c:924} (N:AFPDaemon): AFP logout by ReadyNAS
Mar 12 18:13:15.394101 afpd[12911] {afp_dsi.c:99} (N:AFPDaemon): AFP statistics: 15.56 KB read, 752.70 KB written
Mar 12 18:13:15.394381 afpd[12911] {dircache.c:616} (I:AFPDaemon): dircache statistics: entries: 15, lookups: 354, hits: 335, misses: 19, added: 15, removed: 0, expunged: 0, evicted: 0
Mar 12 18:13:15.394962 afpd[12911] {afp_dsi.c:570} (N:AFPDaemon): done
Mar 12 18:13:15.403119 afpd[1394] {main.c:216} (I:AFPDaemon): child[12911]: done
Mar 12 18:14:20.762137 afpd[12963] {dsi_tcp.c:212} (I:DSI): AFP/TCP session from 192.168.1.141:63242
Mar 12 18:14:20.776505 afpd[1394] {main.c:214} (I:AFPDaemon): child[12962]: exited 1
Mar 12 18:14:20.776826 afpd[1394] {main.c:216} (I:AFPDaemon): child[12963]: done
Mar 12 18:14:20.856485 afpd[12964] {dsi_tcp.c:212} (I:DSI): AFP/TCP session from 192.168.1.141:63243
Mar 12 18:14:20.863519 afpd[12964] {uams_dhx2_pam.c:321} (I:UAMS): DHX2 login: ReadyNAS
Mar 12 18:14:22.000894 afpd[12964] {uams_dhx2_pam.c:210} (I:UAMS): PAM DHX2: PAM Success
Mar 12 18:14:22.017087 afpd[12964] {uams_dhx2_pam.c:653} (I:UAMS): DHX2: PAM Auth OK!
Mar 12 18:14:22.017367 afpd[12964] {auth.c:266} (N:AFPDaemon): AFP3.3 Login by ReadyNAS
Mar 12 18:14:22.055103 afpd[12964] {volume.c:2045} (I:AFPDaemon): CNID server: localhost:4700
