CaryTheLabelGuy
Dec 22, 2011Aspirant
CNID DB error using AFP in Lion
My rig: late 2011 iMac 27inch 3.1Ghz Quad Core i5 running OS X Lion ReadyNAS NV+ RAIDiator 4.1.8 4x1tb Hitachi drives I'm having an issue whenever I try to use AFP on the ReadyNAS NV+. The pro...
franklahm
Mar 13, 2012Aspirant
Fandu wrote: This is a log of the CNID error being generated: ReadyNAS:~# tail -f /var/log/netatalk.log
Mar 12 18:12:33.023880 afpd[12911] {cnid_dbd.c:439} (E:CNID): transmit: Request to dbd daemon (db_dir /c/.timemachine) timed out.
Either the CNID database deamon (cnid_metad) is not running or hanging. You have ssh access to this unit? Are you somewhat familiar with CLI?
Checking whether cnid_metad is running could be done with a command like this:
$ ps -efl | grep cnid
Some background on the CNID stuff:
http://netatalk.sourceforge.net/2.2/htmldocs/configuration.html#CNID-backends
Can you PM me all available Netatalk logs please?!
