CaryTheLabelGuy
Dec 22, 2011Aspirant
CNID DB error using AFP in Lion
My rig: late 2011 iMac 27inch 3.1Ghz Quad Core i5 running OS X Lion ReadyNAS NV+ RAIDiator 4.1.8 4x1tb Hitachi drives I'm having an issue whenever I try to use AFP on the ReadyNAS NV+. The pro...
franklahm
Mar 16, 2012Aspirant
Fandu wrote: chid appears to be running:
ReadyNAS:/var/log# ps -efl |grep cnid
5 S root 1506 1 0 81 0 - 728 - 20:54 ? 00:00:00 /usr/sbin/cnid_metad
0 S root 2226 807 0 77 0 - 1064 - 21:21 pts/0 00:00:00 grep cnid
So it seems to be running but not responding. We'd need stuff like strace or gdb installed on the box in order to determine why and where it's hanging. From your logs the main CNID daemon cnid_metad seems be hanging very early in its startup, because it is not even printing this messages
Feb 26 12:37:59 ReadyNAS cnid_metad[1556]: Set syslog logging to level: LOG_NOTE
which it should display every time its starting. Is there a chance you can install gdb on the unit? Is gcore installed? I can't check because our test unit just died and we're awaiting replacement.
-f
