pl_shibby
Aug 06, 2019Aspirant
Collabora Online stopped working after upgrade firmware to 6.9.3 and newer
I`m currently using firmware 6.9.2 on my Readynas Pro4.
Everything works fine. I`m using Owncloud 10 with Collabora Online 6.0. But after upgrade ReadyNAS firmware to newer version (6.9.3, 6.9.5, also tested 6.10), Collabora Online stopped working. After back to 6.9.2 everything works fine once again.
I tried restore NAS to factory defaults and fresh install owncloud with collabora = the same result
I tried install Collabora in docker instead *. deb package = the same result
I tried different ReadyNAS device(for example RN102) = the same result
I think something has been changed in kernel between 6.9.2 and 6.9.3...
What else i can do to use latest firmware and have working Collabora Online?
FYI update to OS 6.10.1 doesn`t help.
So... i installed PHP7.0 and migrate owncloud 10 to nextcloud 12, then 13->14->15.. then i have to upgrade php to 7.2 (nextcloud 16 is not supported by php7.0). After PHP upgrade i`ve installed nextcloud 16... Now Collabora online works!!
Hope this may help someone.
Best Regards.
The release notes say there was a security update to the kernel that might be getting in your way.
Is Collabora up to date?
FWIW, 6.10.x upgraded apache2, so there are more changes as you upgrade to current firmware.
- pl_shibbyAspirant
Yes, Collabora Online is updated to latest version
collaboraoffice6.0 6.0.10.29-292 amd64 Brand module for Collabora Office 6.0 -29
but on older version was the same.
So why after switch from 6.9.2 to 6.9.3 (rule od small step, Collabora stopped working?
This is the log:kit-06793-06724 2019-04-01 12:52:34.167577 [ loolkit ] ERR Failed to symlink /proc/self/smaps. Memory stats will be missing. (ENOENT: No such file or directory)| kit/Kit.cpp:2390 kit-06750-06796 2019-04-01 12:52:34.771056 [ lokit_002 ] ERR Failed to load: file:///user/docs/0T7drmCzapA9R9Dc/test.xlsx, error: loadComponentFromURL returned an empty reference| kit/Kit.cpp:1685 kit-06750-06796 2019-04-01 12:52:34.771248 [ lokit_002 ] ERR Failed to get LoKitDocument instance for [file:///user/docs/0T7drmCzapA9R9Dc/test.xlsx].| kit/ChildSession.cpp:564 kit-06750-06796 2019-04-01 12:52:34.773256 [ lokit_002 ] WRN Skipping unload on incomplete view.| kit/ChildSession.cpp:98 kit-06750-06796 2019-04-01 12:52:34.773421 [ lokit_002 ] ERR No socket associated with WebSocketHandler 0x43e0390| ./net/WebSocketHandler.hpp:108 kit-06750-06724 2019-04-01 12:52:35.774830 [ loolkit ] WRN Kit connection lost without exit arriving from wsd. Setting TerminationFlag| kit/Kit.cpp:2222
and after back to 6.9.2 Collabora back to life.
I am in vicious circle. I cannot switch to latest OS6 firmware because Collabora stopped working BUT i cannot install latest ownCloud because 10.2.x doesn`t support PHP5.6 whitch i currently using. Sure, i can install PHP7.x in jessie but this is solution for very short time because ownCloud developers already said that PHP7.0 will be also no supported soon. The best way is install PHP7.3 but this require Apache 2.4, so i have to upgrade ReadyNAS firmware to 6.10.x ;)
So this is a big problem for me: have older OS6 and older ownCloud but working Collabora Online OR have latest firmware with latest ownCloud but without Collabora Online.
Best Regards.
- pl_shibbyAspirant
Yes, Collabora is up-to-date (6.0.10.29-292) but on older version was the same.
So why after upgrade to 6.9.3 Collabora stopped working and after back to 6.9.2 back to life? Here is the problem.
This is a big problem for me. I cannot use latest OS6 firmware because Collabora doesn`t work. BUT i have to upgrade firmware because the latest ownCloud doesn`t support PHP5.6... The best way is install PHP7.3 for future owncloud releases but for that i need apache2.4.
Best Regards
- pl_shibbyAspirant
