gryhnd
Sep 12, 2013Aspirant
Compression Overhead?
ReadyNAS 104 with 3x2TB Seagate drives, Raid5 via X-RAID I'm wondering what the overhead of the built in compression option for shares is? Would turning it on cause a noticeable lag in read/write c...
gryhnd
Sep 13, 2013Aspirant
mdgm wrote: I would think there would be some performance difference. The bottleneck on the 104 is not the gigabit NIC but rather the CPU and/or the RAM (both of which are soldered on i.e. not replaceable)
Very well, but what IS that overhead? "Some" isn't much of an answer, lol. There's no tests that you guys have run that say for example: "on average, use of compression with /drives X from the HCL/ results in a 5% reduction in overall read performance, and a 10% in write performance on a ReadyNAS 104."?
