Zabkareadynas
Aug 03, 2015Aspirant
Configuration issue with ReadyNAS Ultra 2 Plus on OS 6.2.4
I just upgraded my ReadyNAS Ultra 2plus (x86) from OS 4.2.27 to OS 6.2.4. And Yes, I do know this is not supported by Netgear. I followed the instructions from a previous thread posted on 4/1/2013 ...
- Aug 06, 2015
Thank You very Much. I consider this issue resolved.
mdgm-ntgr
Aug 03, 2015NETGEAR Employee Retired
That issue is purely cosmetic and can be ignored.
- ZabkareadynasAug 06, 2015Aspirant
Okay. No problem. I can handle a little cosmetic issue. I was just wondering if others also noticed this, or did I do something wrong. I have two more Ultra 2+ that I am looking to upgrade to OS6, and I would like to correct any mistakes before I update them.
- mdgm-ntgrAug 06, 2015NETGEAR Employee Retired
That is normal.
By displaying it that way without needing to tell our system how many drive bays a legacy unit has it will show all the drives even in a legacy 12-bay rackmount system.- ZabkareadynasAug 06, 2015Aspirant
