leamal
Jan 08, 2012Aspirant
Connect Marantz MCR603 to Music Streamed from ReadyNAS Duo
I have a Melody Media (MCR603) that is connected to my network and I have been successfully streaming music from my computer using either Windows Media or Logitech Music Server. I have just purchased ...
fuzzyduck2
Jan 16, 2012Aspirant
I have got my MCR603 partially working so I'm not sure if I can shed any light, or indeed, if anyone can help me.
Before I got the ReadyNas Duo the 603 would not see my Windows 7 laptop running ITunes. I then got the ReadyNas and changed my router to a Netgear 3300. After doing yet another rescan of the media using the ReadyDLNA section in streaming services on RAIDar, my 603 can see some but not all of the music the ReadyNas is storing. (Still nothing on Win7 ITunes)
I cannot say if the 603 can see all the music via the Album/Artist/Genre menus as there is so much, but when I hit enter on Browse Folders on the 603 I can only see some of the directories on the ReadyNas even though some of the missing ones contain music. I thought there might have been a difference between creating a folder in Explorer and doing it via RAIDar (even though that uses Explorer), but I have just created two directories via each method, put an mp3 in each and did a rescan media in RADIar but neither directory can be seen on the 603. I have checked the permissions on folders that can be seen by the 603 and those that can't and they appear to be the same.
So, my problem is that I can only see some of the music on my ReadyNas, any ideas why?
