espri
Apr 09, 2016Aspirant
Connect ReadyNAS Pro 6 to WLAN
For several years I have happily and successfully used a NAS, most recently a Netgear ReadyNAS Pro 6 with RAIDiator 4.2.26, mainly to store the library for iTunes and a Sonos music system (a Mac with...
Apr 09, 2016Guru - Experienced User
What router are you using for the wired network?
espri
I think of the wired network as being primarily attached to the NIC in my Mac. There isn't any Internet router as such - though that's not quite true, for the old Netgear MBR624GU router is still plugged into the wired network (though without any SIM card - I had hoped to use that router as a DHCP server that the Sonos devices would recognise but that didn't seem to help me).
