msq's avatar
msq
Apprentice
Oct 04, 2017
Connect to ReadyNAS Duo from RAIDar after factory reset
Hello,   Trying to bring back to life my old RND2000 v1. The problem is I can't connect from RAIDar to the device after factory reset to choose Flex-RAID over (default) X-Raid. Here are the steps: ...
  • StephenB's avatar
    Oct 05, 2017
    If the NAS is using 192.168.168.168 then it is not reaching the DHCP server.  You should probably try 192.168.168.100 in the PC and 255.255.255.0 as the subnet mask.  Also you should try using direct-connect (connecting the ethernet cable directly between the duo and the PC - not through a router or switch).
    Also, use RAIDar 4.3.8 for this, not the newer RAIDar 6.3: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
ProSupport for Business
