msq
Oct 04, 2017Apprentice
Connect to ReadyNAS Duo from RAIDar after factory reset
Hello, Trying to bring back to life my old RND2000 v1. The problem is I can't connect from RAIDar to the device after factory reset to choose Flex-RAID over (default) X-Raid. Here are the steps: ...
- Oct 05, 2017
If the NAS is using 192.168.168.168 then it is not reaching the DHCP server. You should probably try 192.168.168.100 in the PC and 255.255.255.0 as the subnet mask. Also you should try using direct-connect (connecting the ethernet cable directly between the duo and the PC - not through a router or switch).
Also, use RAIDar 4.3.8 for this, not the newer RAIDar 6.3: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
msq
Oct 05, 2017Apprentice
Yup - RAIDar 4.3.8 was the solution for that. Apart from the fact I had to install 32b java it worked out of the box. Seems like network wasn't problem here.
Thank you for your help!
