CetaceaLab
Aug 06, 2015Aspirant
Connecting ReadyNas to an existing LAN
I am using a Ubiquiti Toughswitch router for a LAN to record multiple underwater microphone signals. Until now I have been using a portable HDD to store the data. Due to enormous amount of data comin...
CetaceaLab
Aug 07, 2015Aspirant
Thanks for your reply.
- the PC and 314 are both connected to the router
- the router is set to static IP address, does it need to be changed to dhcp?
- I can acces the 314 through radar but cannot manipulate the webpage it only shows the intro page listing the firmware, which is 6.1.4
- no Users setup as of yet
- the data comes in as .wav files and is managed by a software program which lets me choose folders to save the files in.
Aug 07, 2015Guru - Experienced User
Can you tell us what the IP address of the PC and the 314 are? It sounds like they are not in the same address range.
RAIDar will tell you the 314's address.
