Paul_White
May 21, 2021Guide
"Connecting to the admin page"
Hi, I can see from searching that this has happened to others. My NAS did an upgrade yesterday to 6.10.5 and now when I try to access the admin page it is looping i.e. it asks for the username and ...
Paul_White
May 21, 2021Guide
I have done a factory reset and re-installed the firmware and for a little while everything worked fine.
Within a matter of minutes the unit has started looping again.
The firmware re-installed was either 6.10.5 or it has updated to this version.
Is there any way of going back to 6.10.4?
May 22, 2021Guru - Experienced User
One poster found they could log in with internet explorer. One important aspect - the log in also required that they not maximize the browser window.
If you can log in, then you can downgrade back to 6.10.4
- Paul_WhiteMay 23, 2021Guide
I have tried ie (not maximised) and that loops too.
I will try some other browsers and report back.
