dpitts
Dec 27, 2018Aspirant
Connection Limit ReadyNAS 3138
Everything was great before the people arrived... :-)
This weekend I setup the new ReadyNAs. Moved files from a Windows 2008 server. We have about 9 MACs and about 6 PCs. I connected every...
Marc_V
Jan 01, 2019NETGEAR Employee Retired
Hi dpitts
It's definitely not a connection limit. Have you checked the logs for any possible errors? Are they receiving any messages or it just freeze when trying to access?
Have you tried doing a reboot? or have you tried doing a firmware update on the NAS?
Regards
dpitts
Jan 01, 2019Aspirant
Marc_V - thank you for replying and trying to help.
They just hang - it sits there... sometimes the Finder window closes (MAC). Other times on the PC the Explorer window starts saying "Not Responding".
LOGS. I login to the Wed interface. Click System. Click Log. and on the left side I see Errors, Warnings, Info. I look at those and I don't see anything specific.....
I'm a newbie....but it seems there should be more detailed logs....somewhere? Help.
- Marc_VJan 02, 2019NETGEAR Employee Retired
- dpittsJan 03, 2019Aspirant
- StephenBJan 03, 2019Guru - Experienced User
dpitts wrote:
ctechs says downgrade, Marc_V says upgrade.
It's a bug introduced in 6.9.4. I saw similar timeouts with 6.9.4, and chose to downgrade to 6.9.3. That solved it for me.
Upgrading to 6.9.5 beta might also fix it (hopefully it will, since it will be released soon).
