abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
mdgm-ntgr
Dec 13, 2011NETGEAR Employee Retired
That doesn't necessarily follow.
Only a specific version of the WD20EARS (see notes column) is listed as compatible.
What's the suffix appended to the end of the model number for your WD10EARS?
