abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
mdgm-ntgr
Dec 14, 2011NETGEAR Employee Retired
It's a different version of the drive so has compatibility issues that one with the same suffix as the supported WD20EARS would not.
Do you have a good backup?
