abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
abeman
Jan 14, 2012Aspirant
Hi
I can access the files on my nas perfectly, and after the first write fails, they also work fine.
from what I read on this page http://www.readynas.com/?page_id=82
would that mean that I could resync my drives by reinserting them or something?
how can I find out if my drives have 4k or 512B sectors?
Added support for 4K sector drives. If you have already installed 4K sector drives with 4.2.11 or earlier, you can replace each disk one by one, allowing it to complete resync, and all your disks will be 4K aligned, and your performance should be on par with similar 512-byte sector drives.
