abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
abeman
Jan 14, 2012Aspirant
***** partition output for sda *****
Disk /dev/sda: 1953525168 sectors, 931.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 94DDF162-9513-4B5C-8409-0FECBDC35A51
Partition table holds up to 8 entries
First usable sector is 4, last usable sector is 1953525164
Partitions will be aligned on 8-sector boundaries
Total free space is 5101 sectors (2.5 MiB)
Number Start (sector) End (sector) Size Code Name
1 4 8388611 4.0 GiB FD00 Linux RAID
2 8388612 9437187 512.0 MiB FD00 Linux RAID
5 9437189 1953520064 927.0 GiB FD00 Linux RAID
Disk /dev/sda: 121601 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
***** partition output for sdb *****
Disk /dev/sdb: 1953525168 sectors, 931.5 GiB
Disk identifier (GUID): E302ADA2-DF10-473F-9EC8-A6CBE54B08BD
Disk /dev/sdb: 121601 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
***** partition output for sdc *****
Disk /dev/sdc: 1953525168 sectors, 931.5 GiB
Disk identifier (GUID): F85875C1-A43E-4493-B2CD-7780CD9E7A4E
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 1953525134
Total free space is 5041 sectors (2.5 MiB)
1 64 8388671 4.0 GiB FD00 Linux RAID
2 8388672 9437247 512.0 MiB FD00 Linux RAID
5 9437256 1953520131 927.0 GiB FD00 Linux RAID
Disk /dev/sdc: 121601 cylinders, 255 heads, 63 sectors/track
/dev/sdc1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sdc2 0 - 0 0 0 Empty
/dev/sdc3 0 - 0 0 0 Empty
/dev/sdc4 0 - 0 0 0 Empty
