abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
mdgm-ntgr
Jan 14, 2012NETGEAR Employee Retired
O.K. The third disk /dev/sdc is 4k sector partition aligned. The other two are not. So you could hot-remove (remove while NAS is on) one disk at a time, wait a bit, then hot-add (add while NAS is on) wait for resync to complete and volume status to return to redundant then move onto next disk.
