abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
abeman
Jan 14, 2012Aspirant
so I need to do that for all the disks right?
and does it matter what disk I remove add first?
what is the chance this would mess up my system?
btw thx for the support, netgear support was not much help.
and how do you know that the last one is 4k sector aligned, because of the entries the partition table can hold?
