abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2 each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy for no reason at all... after a while it fails or picks up ...
mdgm-ntgr
Jan 14, 2012NETGEAR Employee Retired
abeman wrote: so I need to do that for all the disks right?
No just /dev/sda and /dev/sdb. /dev/sdc (probably disk 3) is already 4k sector partition aligned. One of the logs would indicate which is which disk.
abeman wrote:
and does it matter what disk I remove add first?
Only if one or more of your disks is failing.
abeman wrote:
what is the chance this would mess up my system?
If a disk is failing, yes.
abeman wrote:
btw thx for the support, netgear support was not much help.
Well I'm a user like you, so I don't mind, except my personal preference would be to use supported disks. Disks not on the compatibility list may/may not work.
abeman wrote:
and how do you know that the last one is 4k sector aligned, because of the entries the partition table can hold?
Why you might want to factory reset a x86 ReadyNAS
