HippyEverAfter
Jan 24, 2016Aspirant
Copying files from external drive
Hi, I have a Thunderbolt external hard drive with a usb3 connection. Connected the drive to my Personal readynas a little while ago to copy a lot of mp3 files over to the nas drive but it was pai...
cpu8088
Jan 24, 2016Virtuoso
copying via wifi will always be slow
use ethernet cable connection
HippyEverAfter
Thanks for reply but i was posting specifically about connection via a usb cable.
- StephenBJan 24, 2016Guru - Experienced User
Part of the answer is that even if the USB drive is connected to the NAS you might actually be copying the data over wifi. For instance, if you do a drag-and-drop from finder, the data is read by the NAS from the external drive, transfered to the mac over wifi, transfered back from the mac again over wifi, and then written to the NAS to the internal array.
To avoid the network copy altogether, you need to use the built in backup job in the NAS to do the copying. Otherwise, as CPU8088 says, you should connect the mac to your network with ethernet, and attach the USB drive to the mac. That copies over the network only once, and ethernet is faster and more reliable than most wifi links.
How fast the various ways copying are depends on what ReadyNAS model you have and what firmware it is running. Can you provide that information?
- HippyEverAfterJan 24, 2016Aspirant
Thanks for the extra information. It is a lot clearer to me now.
