nowthennet
Sep 03, 2011Aspirant
Copying from the ReadyNAS Duo to the same ReadyNAS Duo
When I copy data from a share on my ReadyNAS Duo to the same share on my ReadyNAS Duo, it is incredibly slow. I am assuming that this is because it is copying data from the RND across my network to m...
WhoCares_
Sep 03, 2011Mentor
You can install a file manager type add-on from the add-on section. Since those run directly on the ReadyNAS they should do what you want.
-Stefan
-Stefan
