ipb_uk
Oct 26, 2017Aspirant
CPU Fan stuck on 4218 rpm
Hi, The CPU of my Pro RNDP6000 is stuck on 4218 rpm. The box is on 6.9.0. The cpu temp is 47. The fan starts off slow at around1500rpm and works its way up 4218 rpm after about 10 minutes and st...
Supertramp11
Oct 26, 2017Luminary
Sorry for you to hear this, but happy you are sharing this.
I'm still running my PRO 6 on 6.5.0 (my best fan behaviour experience since I bought it 5 years ago) and will avoid 6.9.0. based on your message.
Needless to say that I hope for you that your problem gets fixed.
ipb_uk
Hi,
Nothing to do with 6.9.0 because as stated it's been like this for months.
Regards Ian.
- SandsharkOct 26, 2017Sensei
Do you know if your CPU fan is of the three-pin variety connected to the I/O board or 4-pin variety connected to the motherboard? Another user reported a similar problem and he got it fixed by making changes in the system.conf file, though he had just changed from 4.3.x to 6.x. Did it happen at some OS update? Somewhere along the line in 6.x, Netgear may have left out the configuration for the 3-pin fan in the 6-bay Pro models. I frankly have no idea how it could tell which it is, so maybe that process just fails sometimes during an update.
Take a look here: CPU-fan-stuck-on-full-speed-on-upgraded-x86-OS6-pro-business
- ipb_ukOct 26, 2017Aspirant
Hi,
It's the four pin to the motherboard.
OK, so SSH into the NAS and look at /etc/sensor.d and see if i you have both a system.conf and a pro6-fan.conf.
pro6-fan.conf should look like this:
chip "w83627dhg-*" ignore fan3And system.conf like this:
chip "w83627dhg-isa-*" label in1 "DDB18" set in1_min 1.62 set in1_max 1.98 label in2 "AVCC" set in2_min 3.3 * 0.90 set in2_max 3.3 * 1.10 label in3 VCC3 set in3_min 3.3 * 0.90 set in3_max 3.3 * 1.10 label in4 VCC1_25 set in4_min 1.17 set in4_max 1.32 label in5 "VCC1_5" set in5_min 1.41 set in5_max 1.58 label in6 "VCC1_05" set in6_min 0.98 set in6_max 1.10 set in7_min 3.3 * 0.90 set in7_max 3.3 * 1.10 set in8_min 3.0 * 0.90 set in8_max 3.3 * 1.10 label fan1 "System" set fan1_min 600 label fan2 "CPU" set fan2_min 150 label fan3 "System" set fan3_min 600 ignore fan4 ignore fan5 label temp1 "System" set temp1_max 80 ignore temp2 ignore temp3 ignore cpu0_vid ignore intrusion0system.conf is actually just a link to etc/frontview/sensors/NV6.conf.
I'd say your fan or the fan controller was broken, but that would normally make it start out full on, not ramp up.
