mfinney
Oct 20, 2017Apprentice
CPU fan stuck on full speed on upgraded x86 OS6 pro business (RNDP6350)
Just upgraded from OS 4.2 and all is working apart from fan control. Post the OS6 install, front view reported an extra ‘system’ fan and reported CPU fan running at 0rpm. My guess is, one of the rep...
- Oct 20, 2017
My Pro6 has the 4-pin fan attached to the motherboard rather than the 3-pin fan attached to the I/O board. I have not had to make any changes to those files, which includes settings for the non-existent third fan and no ignore fan 3. What it does have, that yours also has, is ignore temp3 in pro6-fan.conf. This is a guess, but I think you may need to swap the temp2 and temp 3 commands in the Pro6 file so you ignore temp2 and compute temp3. That guess is based on temp# being associated with fan# instead of association by label. The system.conf file in my 4200 seems to bear that out. There, fan2 and temp2 are CPU.
Sandshark
Oct 20, 2017Sensei
mfinney
Oct 21, 2017Apprentice
Sandshark, thanks very much for your fast response.
You inspired me to move my CPU fan lead to the main motherboard (even though mine arrived from factory connected to the IO card). Once I moved the lead and tweaked the default system.conf by adding the line 'ignore fan3' all is well.
Fantastic - thanks for all your help! Feels like I have a new NAS :-)
