jpcuk
Aug 31, 2013Aspirant
CPU temp increase since upgrade from 6.0.8 to 6.1.1
I recently upgraded an RN312 that was running 6.0.8 to 6.1.1. Since then, the average CPU temp has increased to approx. 47 deg C (used to be roughly 10 deg C lower). I've checked active processes that...
mdgm-ntgr
Aug 31, 2013NETGEAR Employee Retired
Downgrading to 6.0.8 should be fine though if important data is primarily stored on the RN312 you may want to ensure your backup is up to date first.
