tcleland
Mar 27, 2014Aspirant
Crashing during factory reset
Hi folks - This is a new problem based on the ReadyNAS Pro Business 6-disk discussed in viewtopic.php?f=65&t=75720 I finally decided it was time to factory reset the whole system. So I did. B...
Mar 27, 2014Guru - Experienced User
The pro will boot with only one disk.
I am thinking it is more likely a system failure than the disks, based on your writeup.
Though I would probably run seatools on the original disk 6, and maybe others to confirm that they are all good.
I think I'd also try removing the UPS altogether, just to rule out any possibility that it is providing inadequate power. How old is the UPS? Did you ever replace the battery?
