tcleland
Mar 27, 2014Aspirant
Crashing during factory reset
Hi folks - This is a new problem based on the ReadyNAS Pro Business 6-disk discussed in viewtopic.php?f=65&t=75720 I finally decided it was time to factory reset the whole system. So I did. B...
tcleland
Hrmm. I suspect that you're right. By "system failure" in this context I assume you mean something broken in the low-level hardware that can't be modified by users? Or is there something I can do? Any chance that it's a RAM failure, for example, even though the RAM check from the boot menu told me that it was fine?
I don't think it's a shortage of power -- that same UPS is also supporting two other ReadyNAS boxes (both of which are doing fine), a SonicWALL firewall, and a smart switch. But it could be, conceivably, that the particular plug that this box is plugged into is problematic, so I can test that. First by just plugging into the wall, I think, as you suggest.
The UPS is "new" -- though it is "new" from a refurbisher who installed new batteries. Conceivably they are pathetic batteries, though this refurbisher does a lot of business in the area and focuses a lot on repeat business, so I suspect they aren't in the sell-and-run game.
Thanks much -
Thom
Thanks much -
Thom
